May 12, 2023 at 12:39 pm
Julen
SubscriberHello Everybody,
I set up my Simulation and I got the following error message:
"The problem Preprocessors   has not converged."
Yet I don't get any recommendation what to do next or any indication on where the problem might be in the Listing viewer. Does anybody know where I can find some input on where to look or is this common?
May 12, 2023 at 1:12 pm
Forum ModeratorMaybe elaborate on which solver and what you were doing at the time?Â
May 15, 2023 at 8:42 am
Julen
SubscriberHello,
I am using Ansys Polyflow and I am trying to model the way a polymer melt flows through a heat sink. I can't really tell you much more, the Listing Viewer doesn't give me much to work with.Â
I will try to change some parameters and hope it works. Its trial and error from here I think.Â
May 15, 2023 at 10:03 am
Forum ModeratorI'm not sure with Polyflow. Check the model settings, mainly boundary conditions and material properties.Â
May 15, 2023 at 10:11 am
Julen
SubscriberThank you, I will start there.
May 16, 2023 at 3:11 pm
Julen
SubscriberHello Rob,
the Simulation I was asking about earlier started working, now I am on to the next iteration and I get the following error, do you know how I can fix it, or at leat tell me where to look. I am new to this, and I am trying as hard as possible to learn! Thanks in advance.
 ***  Starting Step 1  ***
  Parameters and Fields             |  Progress bar(s)  |
 Evolution parameter S   =  7.5500000E-01   |>          |
 Parameter fac       =  5.4328477E+04   |>          |     Â
 Parameter expom      =  1.0000000E+00   |>          |     Â Preprocessors  Â
 Convergence assumed : Rel. var. LT  1.00000E-03
 F.E.M. Task   Â
Divergence detected for field VELOCITIES: iterations cancelled by Expert SystemÂÂ
 Divergence of influent solver occurred !
      *** WARNING *** from [EVOLUT]
     First step does not converge
     It is not possible to start the evolution schemeÂ
   *  Summary of the simulation  *
   *******************************    The computation failed.
   *  Expert tool diagnostics  *
   *****************************   The problem F.E.M. Task    has not converged.
This is the Error message I get in the Listing viewer. I don't really understand why it has a problem with the evolution parameters. I got a failure earlier and I set them to exactly what the Expert System recommended...
Julen
May 16, 2023 at 3:15 pm
Forum ModeratorI don't, but the error is divergence related. I've reminded our internal team.Â
May 17, 2023 at 6:37 am
Julen
SubscriberThanks. Do you know how much time they might need?
Also, I've changed some parameters and run it again. I get the exact same message except one additional thing:
   *****************************   Out of convergence disk.
May 17, 2023 at 10:33 am
Forum ModeratorIt's more when the US find their Polyflow specialist. Â
May 24, 2023 at 3:29 pm
Prashanth
Ansys EmployeeHello Julen
So, what kind of problem is this? On which parameter you are applying evolution? What is your evolution settings?
May 25, 2023 at 6:18 am
Julen
SubscriberHellor Parshanth,
I fixed the problem, thanks for asking though.
I have a different question:
I am trying to simulate the flow of a polymer melt inside an extruder and I need to impose a certain pressure on the outflow (roughly 60 bar). There doesn't seem to be an option to impose a pressure on the outlfow. How would you suggest I fix this problem. Will Polyflow automatically calculate the pressures in the extruder up to the inflow? I am using an imposed volumetric flow rate, so there shouldn't be any reversal of the flow.Â
I don't expect you to give me the solution, but maybe enlighten me on how to approach this whole problem.
Thanks in advance
May 25, 2023 at 10:13 am
Prashanth
Ansys EmployeeYou cannot directly impose pressure values, you can impose suitable normal velocities at inlet and oulet at that pressure conditions.
July 15, 2023 at 9:17 am
耀辉 许
SubscriberHello Julen
I have the same problem as you, I don't know how you solved it, can you tell me the way.Thanks in advance
July 17, 2023 at 9:50 am
Julen
SubscriberHello,
I had the problem because of some false material data I input into my settings. I had some temperature set to 0, which resultend in the denominator of a fraction being 0 as well. I resolved the issue by setting the temperature to 0.001 K.
I hope this helped :)
- The topic ‘The problem Preprocessors has not converged.’ is closed to new replies.
5814
