April 20, 2024 at 11:30 am
javat33489
SubscriberHi all.I'm simulating drilling. The first time I made a model as in the test version of LSTC:ÂÂEverything worked.Now I made another model, in the form of a drill tip for concrete. And when I set rotation to the upper segment of the drill, the mesh is distorted. Why? I use exactly the same settings when I used a model like the LSTC. In the LSTC model, the drill did not touch the SPG (not lagrange mesh) die, but in the new model I made contact, could this be a problem? But if I turn off rotation and leave only translation, the drill doesn't distort:ÂÂBut if I turn off rotation and leave only translation, the drill doesn't distort:ÂÂIn addition, the drill compresses strongly when touched, although it is steel and the LNG die is made of concrete. Previously, this did not happen with the same settings:ÂHELP PLEASE -
April 20, 2024 at 2:16 pm
Tonmoy
SubscriberHi javat33489,
Though I can’t help you with your problem, I’m interested to know how did you do the mesh? Did you use the LS-PrePost or did you use third party meshing tools out there?
Thanks!
- Tonmoy.
April 20, 2024 at 5:08 pm
javat33489
SubscriberSir, I made the mesh in LS-Dyna ACT in Workbench.
April 22, 2024 at 4:35 pm
April 24, 2024 at 5:12 pm
April 24, 2024 at 5:13 pm
javat33489
SubscriberSir, I even tried not to rotate the drill and not to move, but to move the SPG die, but then they are greatly distorted. I don't understand why this is happening.
May 9, 2024 at 7:48 pm
- The topic ‘The problem is rotation.’ is closed to new replies.
