the post-processing of the two-way FTSI
    • haibo
    • ErKo
      Hi
      We can not see the question.
      Can you try to add it so users of the forum can see it and try and help.
      All the best
      Erik
    • haibo
      I combine Fluent, Transient Structural and System Coupling to carry the two-way fluid-solid-thermal interaction. But I can’t acquire the temperature and the heat flux distribution of the solid model from Transient Structural. How should I get these data.
    • ErKo
      Hi
      You need to use a Transient thermal analysis not Transient structural.
      That is the first thing. If you still can not see temperatures once you used the correct system (Transient thermal), then post this question in the Fluent forum for feedback.
      All the best
      Erik
  • The topic ‘the post-processing of the two-way FTSI’ is closed to new replies.
