January 30, 2024 at 6:44 am
jingwang
SubscriberHello, may I ask how the result graph of VarFDTD simulation from the example of array waveguide grating simulation was extracted from the monitor of the output port, and what formula is needed to process it?
https://optics.ansys.com/hc/en-us/articles/360042800633-Arrayed-waveguide-grating-AWG -
January 31, 2024 at 12:23 pm
Afroditi Petropoulou
Ansys EmployeeDear Jing,
Thank you for contacting us.
To get the plot described in Step 4 of the Arrayed waveguide grating (AWG) – Ansys Optics, you need to run the “AWG” analysis first. Then you can either right-click on the T result that has appeared in the Result View window and visualize it or run a script to do that.
If you choose the first option, you will need to go to the plot settings to check the “log10y” option and to change the lambda units.
You can also change the axis limits.
If you want to use script so that you can also post-process the results, you can use the following script:
n=8;
Tres=getresult("AWG","T");
lambda=Tres.lambda;
T=matrix(n,length(lambda));
for (i=1:n) {
T(i,:)=Tres.getattribute("T"+num2str(i));
plot(lambda*1e9,pinch(T,1,i),"lambda", "T");
holdon;
leg=cell(n);
y=linspace(1,n,n);
for (i=1:n){
leg{i}="Re(T"+num2str(y(i))+")";
legend(leg);
setplot("log10y",1);
setplot("y max",1);
setplot("y min",1e-7);
setplot("legend position",8);
holdoff;
The above script should be used as an external script and not in the AWG analysis group. If you want to use it inside the AWG analysis group you can add it at the end of the analysis script but you need to remove the second line (i.e. the T=getresult("AWG","T"); line).
Does the above answer your question or do you need something regarding the analysis script?
Best regards,
Afroditi
January 31, 2024 at 12:27 pm
A small correction. Use this script:
n=8;
lambda=T.lambda;
Tres=matrix(n,length(lambda));
for (i=1:n) {
Tres(i,:)=T.getattribute("T"+num2str(i));
plot(lambda*1e9,pinch(Tres,1,i),"lambda", "T");
holdon;
leg=cell(n);
y=linspace(1,n,n);
for (i=1:n){
legend(leg);
setplot("y max",1);
holdoff;
The previous one will work as external script but will not work inside the analysis. Again if you want to use it in the analysis you need to remove the second line (T=getresult("AWG","T");). In this case, when you run the analysis, the results will be automatecally plotted.
Best regards,
Afroditi
February 1, 2024 at 1:55 am
jingwang
SubscriberDear Afroditi,
thank you very much, it really helps me a lot~
Best regards,
Jing
- The topic ‘the outputs of AWG’ is closed to new replies.
6229
