September 1, 2021 at 10:55 am
Ahmet_Yildiz
Subscriber*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â Â 0.297Â Â TIME= 13:52:48
 The option of ALPX on the MP command is either not available for this Â
 version of Ansys or the appropriate product was not selected for this Â
 session.                                                              Â
 Contact your Ansys support person for more information.
I unchecked the "Filter Engineering data" button as suggested previously and yet i am facing the same problem,
Can someone help please?
September 1, 2021 at 2:46 pmAshish Khemka
Did you check the following post? Please try to see if you are following all the suggestions as indicated:
How do I solve this error in Magnetostatic analysis in ANSYS ÔÇö Ansys Learning Forum
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘The option of ALPX on the MP command is either not available for this version of Ansys’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4017
1461
1287
1135
