Ansys Products
Ansys Products
The nodal solution for displacement command is not giving me a coloured plot
    • teresa ezquerra
      Hi everyone, as it is shown in the image, when I execute the comand PLNSOL,U,SUM I obtain a white plot but I still get the colour scale. I want to get the plot with the colours in the scale, does enyone know what should I do? Thank you!
    • danielshaw
      Is the model constructed using line elements (probably beams)?  If so, you may need to use the /ESHAPE command to show the elements and the contours.
    • teresa ezquerra
      hello, thanks for your response, but unfortunately it is not working. Also the message " BEAM/PIPE elements are detected in the selected element set.  They are
       ignored in the nodal averaging." appears when I want to calculate the von misses stress. Do you know what I have to fix?
      thank you
    • danielshaw
      yes, stresses from beam elements will not be include in nodal stress averaging.  Why are you reviewing nodal results results for beam elements?  Did you review the element results?
  • The topic ‘The nodal solution for displacement command is not giving me a coloured plot’ is closed to new replies.
