March 19, 2021 at 3:33 pm
uwindsorspz
SubscriberHello everyone,nnI am doing the modal analysis of the structure. Is there any way to summarised the max. deformation under all frequencies at the same time? For now, I need note the max. deformation manually, which is a little time-consuming. Thanks for your answer in advance.n -
March 19, 2021 at 11:51 pm
peteroznewman
SubscribernThe deformation of modal analysis is arbitrary. You can request that the max. deformation of every mode be exactly 1.0. Use that and it will take you no time at all to note the max. deformation.n/forum/discussion/2569/comparing-stresses-from-modal-analysis-and-static-analysisn
- The topic ‘The max. deformation under different frequency can be export together or not?’ is closed to new replies.
