May 27, 2024 at 7:56 pm
antoniogutgon
SubscriberHi! I am following the fluid flow simulation module of the Discovery Getting Started track. While doing the Thermal fluid flow example, starting from the .dsco provided (Car Interior Simplified Geometry) I got the following error: "The location for "monitor" is completely supressed. No results available." I followed the video step by step and the surface was already created. What does this error means? How can I solve it and monitor that variable in the surface?
You can see what is described in the image below:
May 28, 2024 at 7:29 am
subashni.satish
Forum ModeratorHello Antonio,
Let me check the simulation at my end and get back to you
- The topic ‘The location for “monitor” is completely supressed. No results available.’ is closed to new replies.
