July 29, 2021 at 8:55 am
frank.shen
The License manager cannot be started.
Error: Problems were encountered while attempting to stop the following process(es): ansysli_server.exe, ansysli_monitor.exe The license manager is running. However, its FlexNet component is not running correctly. To resolve this issue, please manually kill (in the order listed) the ansysli_monitor, ansysli_server, and lmgrd processes, and then start the license manager again through the License Management Center.
July 29, 2021 at 10:23 am
Charudatta Bandgar
SubscriberHello Frank Shen Have you tried the way the message has been prompted? See if doing that works, in the meantime I will look into any possible cause of it.  If the stated method does not work, please send the diagnostics files as mentioned in this post: Discovery Enterprise licensing: Gathering diagnostic information Regards.-
July 29, 2021 at 11:09 am
frank.shen
SubscriberHi Charudatta Bandgar ,
Thanks for your reply.
I have tried the method. Shut down some process manually. It worked for a few seconds and quickly turned to the same status again.
Thanks a lot!
July 30, 2021 at 8:56 am
Charudatta Bandgar
SubscriberMatt Madore Can you help with this?
July 30, 2021 at 11:09 am
ANSYS_MMadore
Forum ModeratorWe will need diagnostics.   Please send the diagnostics files as mentioned in this post: Discovery Enterprise licensing: Gathering diagnostic information
- The topic ‘The License manager cannot be started.’ is closed to new replies.
