September 3, 2025 at 4:34 am
September 3, 2025 at 11:02 am
Sascha Hell
Ansys EmployeeHello,
could you please check whether you can edit the legend through scripting, as a workaround?
You can find how to use Mechanical scripting to change the legend in below article.
https://discuss.ansys.com/discussion/513/working-with-legends-in-mechanical-scriptingPlease let me know if this helps.
Best regards,
Sascha
September 3, 2025 at 11:11 pm
UNI
SubscriberThank you so much for replying faster than anyone else.
Afterwards, I tried looking for other solutions, and I was able to resolve the issue using the method I found at this address.
If I come across something I don’t understand in the future, I’d appreciate your help again.
Have a great day!
https://discuss.ansys.com/discussion/4498/how-to-edit-any-legend-value-with-a-ui-box-in-mechanical/p1?tab=accepted
September 4, 2025 at 7:26 am
ErKo
Ansys EmployeeHi
Thank you for the feedback - good to hear that this article helped.
In order to help others, did you use environmental variable in Windows, ANS_USE_OPENGL_LEGEND_EDIT to 1, to resolve the issue?
Thank you and all the bestÂ
Erik
September 5, 2025 at 12:52 am
UNI
SubscriberÂ
Hello Erik,
First, the method I initially used was to go into Ansys Workbench (Mechanical) → Automation Tab → Manage and add the coding uploaded by Rohith Patchigolla, which creates a separate Contour Editor.
After reading your post, I also tried adding the environmental variable ANS_USE_OPENGL_LEGEND_EDIT. With this method, I was able to confirm that the Edit button, which appears when right-clicking the Legend, also worked properly.
In conclusion, both methods were successful. I hope this helps.
Method1
You can check Rohith Patchigolla’s coding at the above link.
Method2
https://install.simutechgroup.com/error-cant-edit-mech-contours
I was able to learn how to add 'ANS_USE_OPENGL_LEGEND_EDIT' from Solution 1.Â
September 5, 2025 at 9:24 am
ErKo
Ansys EmployeeThat is great - thanks for the feedback, which I am sure other forum members will find very useful
5639
1885
1403
1303
