3D Design
3D Design
The Help – czech translation in version 2021R2
    • Lukas Janicek
      Hello, when I want to go to the help in czech language, I saw the error page only and then I have seen the english help.   It is issue in the version 2021R2. Everything is ok in the version 2021R1.   Could you fix the issue, please?   Thank you.   Regrads, Lukas
    • Subashni Ravichandran
      Hello Lukas
      Thank you for reporting this. Let me check from my end and get back to you here.
      Hello Lukas
      I understand that Help is not available in Czech language for Discovery
      • Lukas Janicek
        Hello Subashni I have meant the translation of help for Ansys SpaceClaim.  The translation of help for Spaceclaim 2021R1 is available, but for 2021R2 is not. You can see in the attached video or you can test it, if you switch to czech language in SpaceClaim 2021R1 and 2021R2 and then go to the help (f1 key).   Lukas
        ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
  • The topic ‘The Help – czech translation in version 2021R2’ is closed to new replies.
