April 16, 2024 at 8:01 am
yizhang shao
SubscriberThe fluuent application cannot be started through workbench but it can be started separately in win64 folder. I reinstall Ansys several times but still don't work. Every time I delete the relevant system variables. The Ansys version is 2023R1, I use Win11 system. The first time this issue started because I modify "udf.dat" .
April 18, 2024 at 12:10 pm
SVV
Ansys EmployeeHi,
Could you please share the error messge you are getting when lauching fluent from WB. I assume the working directory and root directory mentioned in the Fluent launch panel is correct.
April 18, 2024 at 12:17 pm
- The topic ‘The fluent application failed to start through workbench’ is closed to new replies.
1530
1386
1209
