May 17, 2024 at 10:17 am
Jim Beet
SubscriberI am conducting a simulation of a spinning golf ball traveling through the air. The simulation method involves using a moving reference frame. Two fluid domains are created: an outer rectangular domain and a rotating spherical domain containing the golf ball.When examining the contours and vectors, it appears that the golf ball is only experiencing rotational motion and not the tangential motion from the inlet flow. The wake region behind the golf ball is pointing vertically downward, which is incorrect.Â
I am using a steady-state, standard k-epsilon model. The inlet speed is set to 45 m/s, and the rotational speed of the domain containing the golf ball is set to 4000 rpm. The walls of the golf ball are set to a moving wall condition with 0 rpm relative to the adjacent rotating domain. I am trying to make the flow similar to the first picture ( which is how it suppose to be). Could you please help me resolve this issue?
May 17, 2024 at 10:56 am
Forum ModeratorWhat is the surface setting between the two fluid zones?Â
May 17, 2024 at 2:01 pm
Jim Beet
SubscriberHi rob, thanks for the reply. I am not sure on the surface setting between the two fluid zone, I designed the domain using boolean subtract on both outer and rotating domain. How do I inspect the fluid zones surface settings?Â
May 17, 2024 at 2:15 pm
Forum ModeratorIn the solver you'll have either interior:fluid:fluid (or similar, fluid being the zone name) or interface. Because of the scale it's difficult to see whether you have flow through that boundary, and what that boundary does to the flow.Â
May 17, 2024 at 2:25 pm
May 17, 2024 at 2:37 pm
Forum ModeratorOK, so nonconformal interface between the two zones. Check the mass flux on both interface surfaces and also plot pathlines down the centreline (release from a line) so we can see what's going on.Â
May 17, 2024 at 5:18 pm
Jim Beet
SubscriberIm not sure how to do the mass flux and pathlines, is there any source you can recommend for me to learn?
May 18, 2024 at 7:28 am
May 18, 2024 at 7:48 am
May 20, 2024 at 8:06 am
Jim Beet
Subscriberhi rob, please reply. I really need your help hereÂ
May 20, 2024 at 8:37 am
Forum ModeratorI don't work weekends! UK office hours only, other than this week where I stop at close of Wednesday for a week off.Â
There's something odd with that result. Not least that I'd expect pathlines to be continuous. Please can you post the Pathline panel?
May 21, 2024 at 2:55 pm
May 21, 2024 at 2:59 pm
Forum ModeratorTurn off Relative and replot.Â
May 21, 2024 at 6:04 pm
May 22, 2024 at 12:33 pm
Forum ModeratorYou can turn off the spin! The pathlines follow the flow, so it looks like there is a 3d effect too if you look at where they finish up.Â
May 22, 2024 at 5:54 pm
Jim Beet
SubscriberI cant turn off the spin as I want to simulate a rotating golf ball passing through the air
May 30, 2024 at 2:23 pm
Forum ModeratorBut you can if you want to check the influence on the flow.Â
- The topic ‘The flow from the inlet did not pass through the golf ball in the rotating domai’ is closed to new replies.
5849
