TAGGED: #multiphase_models, cfd-udf-fleunt, udf, udferror
March 10, 2026 at 8:18 pm
rre285
SubscriberHello,
I was trying to run my UDF in Fluent 2023 R2 to do a meltflow simulation. The udf seems to be good, building and loading went good. the initialtization is okay, but whenever I run calculation, I resieve this error: "===================================================================================
= Â BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 0 PID 22572 RUNNING AT a074478
= Â EXIT STATUS: -1 (ffffffff)
 The fl process could not be started."I am running in parallel mode. I am not sure what is the reason behind this failure.
March 11, 2026 at 9:55 am
Forum ModeratorCan you run any models on that hardware configuration?Â
March 11, 2026 at 2:40 pm
rre285
SubscriberThank you for answering. Yes I've tried a simpler UDF and it was working fine, so I am not sure if the issue is with the parallel mode or with my complex udf.
March 11, 2026 at 2:45 pm
Forum ModeratorIf a simple UDF works, it's likely your more complex UDF. Was anything more diagnostic printed before the node failures? The section you pasted is just a node kill message, and I'm expecting something just happened just before that.Â
March 11, 2026 at 2:50 pm
rre285
SubscriberNothing appeared before, there was a message that hyperid initialization is done then this error appears when I run calculation. So I have changed a little in the settings and this is the new error message that I recieved:
job aborted:
[ranks] message[0] process exited without calling finalize
[1] terminated
---- error analysis -----
[0] on A074478
C:\PROGRA~1\ANSYSI~1\v232\fluent\fluent23.2.0\win64\3ddp_node\fl_mpi2320.exe ended prematurely and may have crashed. exit code 2---- error analysis -----
5639
1885
1403
1298
