October 16, 2024 at 6:10 am
qc1583
SubscriberWhen running AQWA in Workbench, the error "AROOTL:CALSSB FAILED" appeared. What is the cause of this?
October 16, 2024 at 7:34 am
Mike Pettit
Ansys EmployeeHello,
Are there any other error messages in the Output window? What kind of structure are you analysing - are you able to share a screenshot?
CALSSB is part of the code which runs the Shear Force/Bending Moment (SF/BM) calculations. In Aqwa Workbench, these calculations are turned on by default. If you are not interested in SF/BM results, you can turn the calculation off by clicking on the Part in the Outline tree, then scrolling to the bottom of the Details panel, and setting 'Calculate Shear Force/Bending Moment' to 'No'.
Mike
October 17, 2024 at 2:39 am
October 17, 2024 at 2:52 am
qc1583
SubscriberHello,
I couldn't find the option 'Calculate Shear Force/Bending Moment' that you mentioned.
Could you please confirm if it is located under 'Hydrodynamic Diffraction' in the 'analysis setting'?
THANK YOU
October 17, 2024 at 3:50 am
qc1583
Subscriber"I am mainly studying the motion of floating wind turbines. If I disable the 'Calculate Shear Force/Bending Moment' option, will it affect the simulation results?"
October 17, 2024 at 9:46 am
Mike Pettit
Sorry I did not explain very well: click on the structure under Geometry in the Outline tree (see below - here named 'Barge'), and in the Details panel you should find 'Calculate Shear Force/Bending Moment' at the bottom of the settings.
This setting will not affect the simulation results, it will only change the availability of some results in the Hydrodynamic Diffraction system, i.e. you will not be able to plot RAO-based shear forces/bending moments.
Mike
October 17, 2024 at 10:11 am
qc1583
Subscriber"Thank you very much for your response. The issue has been resolved."👍
5814
