March 17, 2019 at 6:33 pm
Oimpa
SubscriberHello
I'm working on an article that uses Abaqus software.
In this article, the author used ''tie'' to glue Two parts of an object.
What is the equivalent of ''tie'' in ansys apdl?
MPC Contact Or other contact algoritm with bonded behavior?
March 17, 2019 at 9:16 pm
peteroznewman
SubscriberYes, Bonded Contact is used to glue faces together in ANSYS. There are several contact formulations that are available for Bonded Contact and MPC is the one I prefer because I like to be able to see the connection elements that are created after the solution is complete.
March 18, 2019 at 6:02 am
Oimpa
SubscriberHello peteroznewman,
Thank you for answering my question.
What is the difference between bonded(always) and No Seperation (always) behavior?
March 18, 2019 at 12:43 pm
peteroznewman
SubscriberBonded is glued with no relative motion allowed.
No Separation allows 3 DOF between the faces. Planar faces in the XY plane, for example, can slide freely in the X and Y directions and rotate about Z.
If your question is answered, please mark the post with Is Solution so others know the Topic is Solved.
- The topic ‘The equivalent of the command ”tie” in abaqus at ansys.’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1236
1118
1015
