October 16, 2024 at 9:05 pm
enej.planinsek
SubscriberHello guys.
I am a student from Slovenia, and I ran into a problem when I installed Ansys. I successfully installed it, but when I try to open a program, there is an error: The directory C:/Users/�iga does not exist. I think the problem is the name itself. � In the path represents Ž, so the program does not recognize Ž, so I need to change it to Z. But I don't think this is an easy fix. Can anybody help me solve this issue? Thanks for your help. -
October 17, 2024 at 12:56 pm
Hongtian CHEN
SubscriberYou assumption is correct, the user name can only be English, what you should do is changing your user name or just create a new accout using an English name, and then install the software again.
October 17, 2024 at 1:01 pm
George Karnos
Ansys EmployeeHello,
Yes, I believe the issue is the special character in the Username.You can try to change the username or create a new user and log in as that user.
October 18, 2024 at 7:13 pm
enej.planinsek
SubscriberHello,
Thank you for help, yes after i made a new user with english name the program started to work perfectly.
5754
