September 9, 2024 at 1:09 am
walaakm10
SubscriberHello everyone
When I view the velocity contour for my results, I can see nothing, as in the attached photo. However, when I view the velocity as a velocity vector, I can see velocity distribution. Does anyone have an idea about why that is?Â
Note: When I take a cross-section of the area, I can see velocity distribution in the contour view.Â
Thanks in advance
September 9, 2024 at 12:18 pm
Federico
Ansys EmployeeIf you have a non-slip boundary condition on the walls, your velocity will be zero on those faces. As you mention, creating different surfaces away from the walls, you should be able to see the velocity > 0m/s
September 10, 2024 at 5:10 am
walaakm10
Subscriberi see, thanksÂ
