LS Dyna
LS Dyna
“the demanded solver was not found in the specified path” error occurs – regd.
    • Jegadeeswaran Sampath
      I have downloaded the both student softwares "Ansys Student and Ansys LS-Dyna student" and then extracted the files and installed the softwares as in shown in this link
      &t=3s
      But I am getting the general errors while using LS Dyna - "the demanded solver was not found in the specified path" and “An error occurred inside the SOLVER module: general error.” and I tried to uninstall and install everything completely but still the errors exist as shown below,
      I need to know how to download the solver along with the install package.
    • VG
      I think the problem is by solver path. In Analysis settings, a solver could be selected. But if that solver is not defined or found, then, that error message shows up.
      The solution is:
      1.    Check the analysis settings – solver control – solver version
      2.    If error shows by selecting a solver, please check “%APPDATA%\Ansys\v232\ACTLSDYNA\lsdyna_solvers.xml”. The solver executables and their paths are defined in that file. Please check the path and make sure that LS-Dyna executable could be found in that path
      3.    Restart Workbench after a change
  • The topic ‘“the demanded solver was not found in the specified path” error occurs – regd.’ is closed to new replies.
