Electronics
Electronics
the constitutive equation of chiral medium
    • huangss_s
      if the user has the permission to modify the constitutive equation  inside the software?
    • Praneeth
      Bbp_moderator
      Hi huangss_s,
      Yes it is possible to edit the material properties in Ansys Electronics Desktop. If you are interested, you can also perform parametric analysis with the material properties.
      Best regards,
      Praneeth, Ansys.
  • The topic ‘the constitutive equation of chiral medium’ is closed to new replies.
