February 22, 2023 at 11:11 am
February 27, 2023 at 1:39 pmAshish KhemkaForum Moderator
Hi Paula,
What is the type of connection you want between the coils? Do you want them to be bonded to each other? If yes, then you can try Share Topology.
Ashish Khemka
- The topic ‘The connection between 2 superimposed coils’ is closed to new replies.
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
543
523
225
209
