September 19, 2024 at 2:26 pm
Philippe CLECH
SubscriberHello. I want to use the Bolt Thread function, but I have some questions. In your requirements it is write " The diameter of the solid model (bolt and nut bodies) should be based on the major diameter (d)". so if I simulate the behaviour of an M10 screw, the diameter of my screw should be 10mm and so should the tapped hole. That's correct.
And an another question:
In my case, I'm simulating an M10 screw with a pitch of 100. so d2 = D2 = 9.188. and is this value what you call the "Mean Pitch Diameter? Can you confirm this for me?
Thnak in adavance for your reply. Philippe. -
September 20, 2024 at 6:58 am
Deepak
Ansys EmployeeYes, the solid model should be based on the major diameter. The Mean Pitch Diameter value you selected is correct. -
September 20, 2024 at 11:36 am
Philippe CLECH
SubscriberHello.
Thank a lot.
Philippe
