November 15, 2024 at 3:16 pm
November 15, 2024 at 3:25 pm
Forum ModeratorCan you check what the surface type is that bounds the rotor? There's a cylinder just a little bigger than the spinning part - look at the black line just outside the red parts of the contour.
Are you using Fluent or CFX?
November 15, 2024 at 3:36 pm
josue
SubscriberThe black line is the projection of the output. the medium is just air. I use fluent.
I have tried another case without a wrapper, and the results are similar to visually normal behavior. but I have seen that the majority use the wrapper, and the same behavior is not achieved.
with wrap
without wrapper
November 15, 2024 at 3:54 pm
Forum ModeratorMiddle image in the first post. There's a very visible jump in the contour. However, can you plot the same image in Fluent? CFD Post doesn't always read the moving zone/refrence frame so your data may be correct but you're displaying the velocity in the wrong reference frame.Â
November 15, 2024 at 4:11 pm
November 15, 2024 at 4:27 pm
Forum ModeratorYou may need to do some more post processing to see what's going on - flow is going about where we'd expect but that may be masked by the higher core velocity. Angular velocity is a good one to review along with axial. Â
How well converged is the model?
November 15, 2024 at 5:36 pm
josue
This last image is the rotor without casing. At first glance, the fluid behavior seems more real. That's why I was wondering if it is normal for the wrappers to have that behavior. Or should they be the same as this last image?
I always match the mesh with share of the spaceclaim. Should it have some interface?
The first image is the convergence curve. -
November 18, 2024 at 3:00 pm
Forum ModeratorWhat casing, and what wrappers? For mrf I'd expect an interior, for sliding mesh an interface pair.Â
6219
