October 7, 2021 at 10:03 am
mrizuwan
Subscriber -
October 7, 2021 at 10:12 am
Devendra Badgujar
Forum ModeratorHello M Rizuwan Can you please confirm if the file downloaded is correct also make sure that it is extracted properly and make sure the executable file is run as administrator. Regards. -
October 15, 2021 at 2:42 am
mrizuwan
SubscriberAlready tried several times, still got same issues.
Then I try to delete/uninstall all spaceclaim and discovery R2. Next, re-extract the DISCOVERY_2021R2_WINX64, of course with "run as administrator", then re-install the file inside ( Discovery and Spaceclaim).
After finish installation, I try to run the Discovery R2, still got same problem. But, the SpaceclaimR2 can open smoothly.
October 18, 2021 at 6:47 am
Devendra Badgujar
Send following log files located at ~
/Ansys Inc . Please send them at ansys-discovery-support@ansys.com Install.log
Install_licconfig.log
Install.err (if it exists)
Also if you are using Remote desktop setup , Please check for compatibility.
Regards.
January 26, 2022 at 3:58 pm
Christian Jensch
SubscriberHi,
have you found a solution for the behavior?
Best
Christian
January 27, 2022 at 12:41 am
mrizuwan
SubscriberNo, Still same issue.
My hypothesis is Discovery Simulation 2021R2 cannot be supported by NVIDIA GeForce GTX 1050 Ti.
My alternative is using Discovery 2021R1, this work nicely but it is disappointing to cannot use latest feature updated in newer version.
January 28, 2022 at 2:16 pm
Christian Jensch
Subscriberin my case it is a RTX 4000, this graphics card is often used and also works with the latest version 2022R1. Only one computer with RTX 4000 unfortunately Discovery does not work and causes the same error here.
Another computer has a Quadro P3200 which should also work. It does not seem to be the graphics card and driver alone, possibly a third hardware/software component!? -
February 1, 2022 at 1:35 am
tyamaguchi
Ansys EmployeeThere are two exe file in Discovery installer and those exe is related this is related Microsoft Visual C++ 2019.
Then you can see two program "2019vcredist_x86.exe" and "2019vcredist_x64.exe" after move to "DISCOVERY_2022R1_WINX64>>prereq".
After that, could you please install it and check whether launched Discovery or not.-
February 1, 2022 at 5:50 am
cfischer
SubscriberI had a similar problem with Discovery 2022R1 as Muhammad and after installing the "2019vcredist_x64.exe" it now works!
Thanks Takahiro for sharing your solution!
Cheers Chris
February 1, 2022 at 7:59 am
tyamaguchi
Ansys EmployeeChristoph Fischer Glad to hear that!
February 18, 2022 at 7:54 am
Nobuyoshi Namito
SubscriberTakahiro Yamaguchi
山口様、お世話になっております。
私も2022R1が起動できずに困っていましたが、ここを見て解決しました。
インストーラーでまとめてインストールしていただければ良いのですが。
解決したので良しとします。
February 8, 2022 at 12:58 pm
Christian Jensch
SubscriberI can confirm that:
Another component that should also be up to date (Graphics card driver) is Microsoft Visual C++, -
May 9, 2022 at 10:00 am
EzgiYapici
Subscriber-
May 9, 2022 at 10:22 am
Devendra Badgujar
Forum ModeratorEzgiYapici
Please try disabling Intel graphics on the machine.
Also please try installing the latest redistributable. You can try installing the appropriate one from here: Latest supported Visual C++ Redistributable downloads | Microsoft Docs
Please try installing the VC_redist.x64.exe and vc_redist.x86.exe for Visual Studio 2015, 2017, 2019 and 2022 package. If you already have 2015 installed, you may need to uninstall before installing this downloaded version.
Regards.
May 9, 2022 at 1:57 pm
EzgiYapici
SubscriberDevendra Badgujar
Hello again,
Many thanks for your quick response and help.
The problem was solved thanks to the fix below. I wanted to point it out in order to help friends who will experience the problem.
"Please try installing the VC_redist.x64.exe and vc_redist.x86.exe for Visual Studio 2015, 2017, 2019 and 2022 package. If you already have 2015 installed, you may need to uninstall before installing this downloaded version."
Thanks again and good work.
Ezgi.
May 9, 2022 at 2:02 pm
Devendra Badgujar
Thanks for your feedback.
Regards.
- The topic ‘The Application Failed To Initialized’ is closed to new replies.
5664
1890
1419
1304
