October 5, 2017 at 4:02 pm
pkys94
SubscriberHello,
just started using ANSYS student 18.2 academic version.
system configuration:- window 10 edu; Intel 8GB ram
After extracting download file, Right-click on setup.exe and select Run as AdministratorÂ
but file is not running. there is no reaction.
how to solve it?
October 5, 2017 at 7:44 pm
vganore
Ansys EmployeePlease try downloading the setup file again. Make sure to disable all antivirus and security software. Simple double click on setup.exe should work.
October 9, 2017 at 9:45 am
fila
SubscriberHello,
I have the same problem. Just windows 7.
I already tried download setup file again, disable all antiviruses and still doesn't work.
Please help
October 9, 2017 at 10:17 am
vganore
Ansys EmployeeWould you be able to run PreReqCheck.exe?
October 10, 2017 at 9:06 am
fila
SubscriberYes, it says:
You currently have:
MS.NET Framework 4.6.2
MS VC++ 2010 Redistributable x86
MS VC++ 2010 Redistributable x64
MS VC++ 2012 Redistributable x86
MS VC++ 2012 Redistributable x64
You still require:
So I think, I don't require anything else.
October 10, 2017 at 7:02 pm
vganore
Ansys EmployeeThis is usually resolved by redownloading or making sure to extract the download. This could be something to do with the OS that's blocking it from running. Try running Windows update to make sure everything is up to date. Apart from this, I can't see any other issue.
November 22, 2017 at 11:36 pm
michal
SubscriberHello,
I have the same problem. I tried install with turn off antivirus, and downloaded again aproximetly 10 times and still doesn't work. I tried also previous versions (17.2, 18.1), but I have the same problem.
This is message from InstallPreReqs: You don't need to install any preraquisites.
Windows 7 (x64), Intel Core i5, RAM: 6GB, Microsoft .NET Framework 4.7.1, MV C++ 2015 Redistributable 14.0.23026.Â
November 23, 2017 at 6:20 am
vganore
Ansys EmployeeWhich graphics card are you using?
November 23, 2017 at 6:49 pm
michal
SubscriberAMD Radeon HD 7550M/7650M
November 27, 2017 at 5:49 pm
michal
SubscriberI formatted my computer and installed all required programs to install ANSYS and I tried to install ANSYS on "clean computer" with all Windows' actualizations, but all the time I have the same problem.
November 30, 2017 at 6:04 pm
michal
SubscriberI solved my problem. I changed browser, from opera to firefox.
December 11, 2017 at 2:42 pm
Windows 8.1 Pro x86
SubscriberYou have to extract the zip file into short named folder that using ONLY english letter
like "C:Setup"
not like "C:downloadfiles...AIMANSYSACADEMICSTUDENT_181_WINX64"
May 23, 2018 at 2:53 pm
729435438
SubscriberHi all,
I had a similar problem. I solved my problem by using the task manager. Right-click your taskbar, choose task manager, switch to details and find ‘setup’. end set up and reopen your setup.exe.Â
June 11, 2018 at 10:02 am
user deleted
Subscriber I solved the same problem (on windows 10) by using this soft: DWS Lite ("Destroy-Windows-10-Spying") and then launching setup.exe through command line as administrator.Â
May 12, 2020 at 7:51 pm
sruchelli
SubscriberHello. I had the same issue, but finally I solved it using the same method detailed by 729435438Â
- The topic ‘The ANSYS STUDENT installation setup file does not run.’ is closed to new replies.
6795
1333
1152
