January 15, 2026 at 9:12 am
vagadiya
SubscriberI am working on simulation of microstrip with Ansys edt 2025 r2 hfss pack and I have question regarding termination of microstrip. For that I am using lumped port and full port impedance is set to 50 ohm. Then is that correct that I am terminating my microstrip with 50ohm or do I need to use lumped RLC for that?
January 16, 2026 at 12:23 am
Takeshi Itadani
Ansys EmployeeAre you in a situation where both ends of the microstrip line are terminated with a Lumped Port?
If so, when calculating S-parameters, if there is input from one Lumped Port, the other Lumped Port will act as a 50 ohm termination. -
January 16, 2026 at 9:19 am
vagadiya
SubscriberThank you for you reply. Yes, both ends of microstrip are terminated with lumped port.So even if I set 100ohm termination on both sides still it will consider 50ohm on other side by default? I am also working on differential line, for which I use 4 lumped port and then I define two differential lines D1 and D2, both ends are terminated with 100ohm. In this case it is also same?Â
January 19, 2026 at 12:05 am
Takeshi Itadani
Ansys EmployeeIf you have set Lumped Ports at both ends of a microstrip and want to use a 50 ohm termination resistance, you should set the Full Port Impedance of each Lumped Port to 50 ohms.
To set the differential impedance and common impedance for a differential line, right-click Ecitations in the Project Manager and select Differential Pairs.... There, set the ports (Terminals) to be used as differential pairs, as well as the differential impedance and common impedance.
After analysis, you can plot differential signals by setting Type to Differential Pairs in the Results settings screen. When plotting with Differential Pairs, the impedance settings for each port are ignored and calculations are performed using the differential impedance and common impedance set in Differential Pairs. -
January 19, 2026 at 7:31 am
vagadiya
SubscriberThank you so much. This helped a lot.
5284
1885
1403
1267
