Tensile test problem
    • ISSAMAZERTY
      I did a tensile test in a static structural :
      I defined the substance (young modulus, Poisson's ratio, multilinear stress-strain curve).
      For the structure, I used the lattice structure.
      The problem with the results, when extracting the curve stress-strain keeps the same values of the material you entered earlier. In the sense that it does not take into account the impact of the structure.
    • Ashish Khemka
      You will get the same stress-strain curve as you entered.
      Regards Ashish Khemka
    • ISSAMAZERTY
      Thanks for your answer.
      I want to get the results of the Lattice Structure.
  • The topic ‘Tensile test problem’ is closed to new replies.
