May 18, 2024 at 10:00 am
Soroush Jafari
SubscriberHello.The project involves impacting a tennis ball (made from hyperplastic rubber with internal pressure) against pre-tensioned tennis strings (made from polyester and nylon) at a maximum velocity of 265 km/h in a direction normal to the string bed. Observing the stress and deformation, the objective is to determine the thinnest possible string for the two materials under test.I thought of conducting multiple steps from simple to more complicated toward the main project:1-Testing the solid ball(with Ansys predefined Explicit>Rubber-2 material) against a rigid plate :-body interaction: proximity-based frictionless-mesh-ball velocity: 7m/s-plate displacements=0-analysis setting:end time: 2e-2automatic mass scaling=nomax no of cycles: 1e7RESULT:The ball bounced back when hitting the plateIssue 1: when we increase the speed(50m/s), some ball elements penetrate and get stuck into the plate, preventing the ball from rebounding. we tried refining the mesh but the issue insisted.issue 2: we acquire the tennis ball and polyester string material properties(stress-strain curve) but assigning it to them gives us an error.error:"You have specified result time(or frequency) = 0.00226447262556333 for a result file which has maximum time(or frequency) = 4.19585521740373e-05. If you specify 0(ZERO), the solution for the final time will be displayed."issue 3: Regarding applying a pretension force on the string in the main analysis, we have difficulty effectively applying it.I attached the verification(Ball_impacting_plate), the main project file and the materials stress-strain data. Materials are also already added to the Engineering Data of the verification file.I appreciate your help.Thank you -
May 20, 2024 at 3:22 am
Kate Bishop
SubscriberYou can try to refine the mesh, adjust contact settings, and use a smaller time step for high velocity. Besides, double-check material properties and output request frequency. Apply pre-stress in a separate analysis or use pre-displacement in the main analysis. Wordle Unlimited
September 12, 2024 at 9:20 am
manishchauchanseo
SubscriberOur escort service in Defence Colony Call Girl is for those who want special company. If you want deep talks or just fun, we have the perfect match for you. Our selection of escorts is top-notch.
October 15, 2024 at 5:06 am
fobofo8381
SubscriberYou can try to refine the mesh, adjust contact settings, and use a smaller time step for high velocity. yuzde
- The topic ‘Tennis Ball(hyperplastic) hitting strings’ is closed to new replies.
1306
