TAGGED: 3d-model, Ansys Discovery, field-distribution, temperature
August 13, 2024 at 1:04 pm
thomason-sanchez
SubscriberHello,Â
In my simulation I do not manage to have the temperature's distribution in Refine mode. If I put an inlet flow at 40°C in Refine Mode , my entire fluid domain will be at 40°C but If I run the same simulation in Explorer Mode I have a temperature's distribution. Why ?
Thanks in advanceÂ
SANCHEZ ThomasÂ
August 20, 2024 at 8:31 am
Devendra Badgujar
Forum ModeratorHello Sanchez,Â
Can you please confirm if you are using LiveGX or Fluent Solver for this? Which version of Ansys Discovery you are using?Â
Devendra
August 21, 2024 at 9:56 am
thomason-sanchez
SubscriberHello,Â
I was using the default one on the 2022 R1 so it must be the LiveGx solver because there is no button to switch solver in the simulation option tab.
Regards
Thomas Sanchez
September 2, 2024 at 6:29 am
Devendra Badgujar
Forum ModeratorHello Thomas,Â
LiveGX solver is available from Discovery 2023 R1 onwards, you should be using the Refine Fluent solver. Can you share an image of your setup to understand this better?Â
DevendraÂ
September 3, 2024 at 11:38 am
September 3, 2024 at 11:47 am
Devendra Badgujar
Can you reproduce this issue with any other sample models available and let me know? If that is also showing the same than it has to do something with your drivers.Â
I would recommend please try updating your graphics drivers from manufacturers website e.g Nvidia.Â
Devendra Â
September 4, 2024 at 11:36 am
thomason-sanchez
SubscriberHello,Â
My graphics drivers are up to date and I tried with others sample I have the same problem.
ThomasÂ
October 5, 2024 at 3:01 pm
Devendra Badgujar
Forum ModeratorHello,Â
Sorry for the delay. Did you try this in the latest version of Ansys Discovery 2024 R2?Â
If its the same, can you try steps from this Discovery Refine: Results fail to appear after solve in Refine stage. - Ansys Knowledge.
DevendraÂ
5894
1306
