Temperature profile input
    • Chandra Sekhar Narra
      Hi all,
      I have a question about the temperature input in Ansys Workbench. Is it possible to give y=m*x+c as a linear  temperature function along the length of the structure in Ansys?
      Thanks in advance!
      Kind regards
      Chandra
    • Sampat Kumar
      Hi Chandra,
      as far as I can understand, you want to enter the temperature value along the length. There is a way that you can enter the temperature value along the length. You should know the temperature value along the length and enter the tabular form in the Ansys mechanical.  Go to the temperature details, select the tabular data in the magnitude cell, and select the axis along the length in the independent variable cell.
      Sampat
      Hi Sampat,
      Thank you very much for your response. With the video you attached, I understand it now.
      Kind regards
      Chandra
    • Sampat Kumar
      You're welcome!
      I'm happy to help you.
      Sampat
  • The topic ‘Temperature profile input’ is closed to new replies.
