March 15, 2023 at 3:59 pm
Asif Haq
SubscriberI running a simulation in transient thermal. I have input temperature dependent thermal conductivity for steel 1010. I am given the following error. The following image is the property that I used. How can I get around this issue.Â
*** WARNING ***             CP =    1.547  TIME= 17:00:34 Using 1 iteration per substep may result in unconverged solutions for Â nonlinear analysis and the program may not indicate divergence in this Â case. Check your results.                       Â *** WARNING ***             CP =    1.547  TIME= 17:00:34 Temperature-dependent properties have not been specified. The     Â THOPT,QUASI option does not perform equilibrium iterations. Small   Â time steps may be required to obtain accurate results.         Â *** WARNING ***             CP =    2.359  TIME= 17:00:34 Element shape checking is currently inactive. Issue SHPP,ON or    Â SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =    2.812  TIME= 17:00:34 Material number 17 (used by element 98218) should normally have at   Â least one MP or one TB type command associated with it. Output of   Â energy by material may not be available.                Â -
March 16, 2023 at 12:23 pm
Aniket Chavan
Forum ModeratorHi, These are warnings, not errors, does your other material have temperature-dependent conductivity as well? The warning could be due to other material.
-Aniket
March 17, 2023 at 9:46 am
Asif Haq
Subscriber -
March 17, 2023 at 11:18 am
Aniket Chavan
Forum Moderatortwo things:
- try deleting the stainless steel defined in the Engineering data
- refresh cells B4 and B5 before solving again.
You mentioned that the solution doesn't complete, are there any other errors in solver output?
-Aniket
March 17, 2023 at 12:15 pm
Asif Haq
SubscriberI have deleted all the information and started the material from scratch. I have input thermal conductivity , young modulus, poissons ratio, and density upto 1600c. WELL IT DID RUN BUT THE THE FINAL TEMPERATURE OUTPUT WAS 9000 degree C.Â
SO i deleted it again and only input thermal conductivity and limited it to 1000 degree C. I have results now. I guess Ansys cant handle temp dependent data above 1000 degree or i might be missing something fairly obvious.Â
March 17, 2023 at 1:01 pm
Aniket Chavan
Forum ModeratorI don't think there's any limit for data in the material. Have you checked the mesh and ITS are as per the required guidelines mentioned here under "Number of substeps per load step, or the time step size":
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/ans_the/Hlp_G_THE3_5.html
-Aniket
- The topic ‘Temperature-dependent properties have not been specified’ is closed to new replies.
5129
1831
1387
1248
