February 16, 2022 at 7:42 pm
mkalel
SubscriberHello,
I was able to figure out the temperature issue in my last discussion post but When I set every top face layer to temperature boundary condition of 200 C. After running the simulation, my temperature profile doesn't seems right to me. when I heat the top face layer of the each element. I am supposed to see the temperature profile covering a big area. (Max and min area) but in my simulation. Almost 90 percentage area is blue which refers to no effect. Why is this? Can somebody help me to fix this issue?
February 18, 2022 at 6:39 pmAshish Khemka
You can plot vectorial heat flux to see how the heat is being dissipated. Does this model has ekill commands implemented as well as you indicated in another post that it may not be working? If there is a bonded thermal contact with other portions of the model then the temperature transition should be continuous.
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘temperature contour not distributing correctly’ is closed to new replies.
5679
1890
1419
