April 22, 2024 at 10:26 am
VAGISH MISHRA
SubscriberHi All,
I am trying to study the temperature (25C to 1000C) and velocity effect (200m/s to 5000m/s) on the impact of 2 solid objects (Steel and Aluminum).Â
I am using the Johnson-Cook model for the materials. Still, I do not see any effect of Velocity and temperature.
Kindly let me know the source where I can learn and correct my mistakes.Â
Thank you in advance -
April 22, 2024 at 1:42 pm
armin.abedini
Ansys EmployeeHi Vagish,
Could you describe how you calibrate and implement coefficients of Johnson-Cook model for the steel and aluminum in your impact simulation?
April 26, 2024 at 4:33 am
April 26, 2024 at 1:42 pm
armin.abedini
Ansys EmployeeThanks Vagish.
I would suggest you investigate this further at local (or element) level to evaluate the strain rates the same elements of the model are experiencing at the two different velocities. If the strain rates experienced by the elements of interest are different, they should demonstrate different mechanical responses provided that the model is set up properly.
- The topic ‘Temperature (25C to 1000C) and velocity (200m/s to 5000m/s) effect on Impact’ is closed to new replies.
