Preprocessing
Preprocessing
TBPT IS NOT SUPPORTED FOR PLAS TABLE FOR MATERIAL 5
    • Adeleine Cabrera
      Can anyone please help me fix the error above. I inserted a command for the structural analysis. I'm trying to input a non-linear stress-strain for different temperatures (2,100,200,300,...degrees celcius).
      /PREP7
      solid65_matid = 9996
      MPTEMP,1,20,100,200,300,400,500,600,700,800,900
      MPDATA,EX,solid65_matid,1,12379.79711
      MPDATA,EX,solid65_matid,2,7740.853655
      MPDATA,EX,solid65_matid,3,5463.276115
      MPDATA,EX,solid65_matid,4,4028.864488
      MPDATA,EX,solid65_matid,5,2636.625645
      MPDATA,EX,solid65_matid,6,1532.568568
      MPDATA,EX,solid65_matid,7,747.8055365
      MPDATA,EX,solid65_matid,8,535.9273011
      MPDATA,EX,solid65_matid,9,336.5124914
      MPDATA,EX,solid65_matid,10,186.9513841
      MPDATA,PRXY,solid65_matid,1,0.2
      MPDATA,PRXY,solid65_matid,2,0.2
      MPDATA,PRXY,solid65_matid,3,0.2
      MPDATA,PRXY,solid65_matid,4,0.2
      MPDATA,PRXY,solid65_matid,5,0.2
      MPDATA,PRXY,solid65_matid,6,0.2
      MPDATA,PRXY,solid65_matid,7,0.2
      MPDATA,PRXY,solid65_matid,8,0.2
      MPDATA,PRXY,solid65_matid,9,0.2
      MPDATA,PRXY,solid65_matid,10,0.2
      TBTEMP,20
      TBPT,,0.00436508, 91.66667
      TBPT,,0.000873016, 183.3333
      TBPT,,0.002, 275
      TBPT,,0.007539683, 410.5812388
      TBPT,,0.013769841, 448.8971382
      TBPT,,0.02, 460
      TBPT,,0.15, 460
      TBPT,,0.16666667, 306.6666667
      TBPT,,0.1833333, 153.333333
      TBPT,,0.2, 0
      TBTEMP,100
      TBPT,,0.000436508, 91.66667
      TBPT,,0.002, 275
      TBPT,,0.02, 460
      TBPT,,0.15, 460
      TBPT,,0.2, 0
      TBTEMP, 200
      TBPT,,0.000392857, 74.25
      TBPT,,0.000785714, 148.5
      TBPT,,0.002, 222.75
      TBPT,,0.00740873, 394.7969301
      TBPT,,0.01368254, 445.2548885
      TBPT,,0.02, 460
      TBPT,,0.15, 460
      TBPT,,0.2, 0
      TBTEMP, 300
      TBPT,,0.000332837, 55.9166667
      TBPT,,0.000665675, 111.833333
      TBPT,,0.002, 167.75
      TBPT,,0.007228671, 376.6471213
      TBPT,,0.0135625, 440.9813622
      TBPT,,0.02, 460
      TBPT,,0.15, 460
      TBPT,,0.2, 0
      TBTEMP, 400
      TBPT,,0.000261905, 38.5
      TBPT,,0.00052381, 77
      TBPT,,0.002, 115.5
      TBPT,,0.007015873, 357.2128672
      TBPT,,0.013420635, 436.2955987
      TBPT,,0.02, 460
      TBPT,,0.15, 460
      TBPT,,0.2, 0
      TBTEMP, 500
      TBPT,,0.000261905, 33
      TBPT,,0.00052381, 66
      TBPT,,0.002, 99
      TBPT,,0.007015873, 282.491995
      TBPT,,0.013420635, 341.2144306
      TBPT,,0.02, 358.8
      TBPT,,0.15, 358.8
      TBPT,,0.16666667, 239.2
      TBPT,,0.1833333, 119.6
      TBPT,,0.2, 0
      TBTEMP, 600
      TBPT,,0.000253456, 16.5
      TBPT,,0.000506912, 33
      TBPT,,0.002, 49.5
      TBPT,,0.006990527, 165.7873517
      TBPT,,0.013403738, 204.554166
      TBPT,,0.02, 216.2
      TBPT,,0.15, 216.2
      TBPT,,0.16666667, 144.1333333
      TBPT,,0.1833333, 72.066667
      TBPT,,0.2, 0
      TBTEMP, 700
      TBPT,,0.000235043, 6.41666667
      TBPT,,0.000470085, 12.833333
      TBPT,,0.002, 19.25
      TBPT,,0.006935287, 78.6331931
      TBPT,,0.013366911, 99.49571004
      TBPT,,0.02, 105.8
      TBPT,,0.15, 105.8
      TBPT,,0.16666667, 70.533333
      TBPT,,0.1833333, 35.2666667
      TBPT,,0.2, 0
      TBTEMP, 800
      TBPT,,0.000242504, 4.583333333
      TBPT,,0.000485009, 9.16666667
      TBPT,,0.002, 13.75
      TBPT,,0.006957672, 39.81042387
      TBPT,,0.013381834, 48.10793178
      TBPT,,0.02, 50.6
      TBPT,,0.15, 50.6
      TBPT,,0.16666667, 33.73333333
      TBPT,,0.1833333, 16.8666667
      TBPT,,0.2, 0
      TBTEMP, 900
      TBPT,,0.000249433, 3.6666666667
      TBPT,,0.000498866, 7.33333333
      TBPT,,0.002, 11
      TBPT,,0.006978458, 22.95742837
      TBPT,,0.013395692, 26.53002521
      TBPT,,0.02, 27.6
      TBPT,,0.15, 27.6
      TBPT,,0.16666667, 18.4
      TBPT,,0.1833333, 9.2
      TBPT,,0.2, 0
      ET,solid65_matid,SOLID65
      CMSEL,S,NM_Con,ELEM
      EMODIF,ALL,TYPE,solid65_matid,
      EMODIF,ALL,MAT,solid65_matid,
      EMODIF,ALL,REAL,solid65_matid,
      ALLSEL,ALL
      /SOLU
    • mrife
      Hi Adeleine
      TBPT defines XY data points for some material models defined by the TB command...which there are none in the APDL code shown.  Not all material models defined with TB use the TBPT command.  Looks like material with ID number 5 in the model is one of those.
  • The topic ‘TBPT IS NOT SUPPORTED FOR PLAS TABLE FOR MATERIAL 5’ is closed to new replies.
