September 18, 2021 at 6:24 pm
Michael93
SubscriberSeptember 21, 2021 at 11:00 amNKC
Forum ModeratorHi @Michael93 Have you tried with just the default initial mesh settings with the TAU mesh algorithm?
If not, remove all the manual mesh refinements settings you have and just run with default initial mesh settings with TAU mesh algorithm.
Regards Navya
September 21, 2021 at 11:35 amMichael93
SubscriberYou mean that i should replace all skin depth mesh elements by "assign mesh operation>on selection>lenght based" or what do you mean by manual mesh refinements? I tried some settings in the initial mesh settings like chosing the classic Mesh Method but because it did not solve the problem i replaced them by the old settings.
September 21, 2021 at 12:28 pmNKC
Forum ModeratorNo, Just delete all manual mesh settings you created under the " Mesh in Project manager window" and go with default initial mesh settings and TAU.
Regards Navya
September 21, 2021 at 2:32 pmMichael93
SubscriberI deleted all assigned meshes and unfortunately the same problem occurs
Viewing 4 reply threads- The topic ‘TAU meshing algorithm does not support such a thin object’ is closed to new replies.
5159
1836
1387
1249
