TANK SEISMIC
    • asder
      NEED TO MAKE SUPERPOSITION TIME HISTORY SEISMIC ANALYSIS
      I MADE SOME CODES NONE OI IT WORKS :-
      You need to model the effect on the fluid in the tank? Or are you looking at the effect on the concrete bit?
    • asder
      dear sir,
      i modeled the tank and i gain all modes of shape from modal analysis
      my problem is time history superposition analysis
      i found some codes for an example like
      IF,transient,EQ,1,THEN
      /SOLU
      ANTYPE,TRANS
      TRNOPT,MSUP,10,DAMP
      TIMINT, ON, STRUCT
      *DIM,force,table,5001,1,1,TIME,,
      *TREAD,force,input4,txt,,
      DELTIM,1E-4,1E-6,1E-4,ON
      AUTOTS, OFF
      OUTRES,,1
      !TM_START=1E-4
      TM_START=0.0
      TM_END=0.5
      TM_INCR=1E-4
      i=0
      *DO,TM,TM_START,TM_END,TM_INCR
      i=i+1
      OUTRES,,1
      NSUBST,1
      TIME,TM
      value=force(TM)
      *STATUS,VALUE,1,,1,,1,,
      F,N_F,FZ,value,,,
      SOLVE
      *ENDDO
      FINISH
      does it right ? if i use acel,timehistorytable,0,9.8 does this load function is right ? i use it for superposition but i found the results is modes shapes only and frequency changed to time , this isn't right solution , why i get that solution
    • asder
      /CONFIG,NRES,1000000000
      /SOLU
      ANTYPE,TRANS
      TRNOPT,full
      *DIM,ACC,TABLE,12002,1,1,TIME
      *TREAD,ACC,seismic-recorded,TXT
      OUTRES,ALL,ALL
      DMPRAT,0.005
      !TM_START=0.005
      TM_START=0.005
      TM_END=60
      TM_INCR=0.005
      i=0
      TIME,TM
      ACEL,%ACC%,0,9.8
      SOLVE
      *ENDDO
      FINISH
      or this
    • jj77
      Stop copy pasting code without any explanations first thing.
      You said: my problem is time history superposition analysis, try running it with the full method (not mode super position).
      If you are still having troubles, explain in detail what the problem is, and attach images to show what you mean in your explanation so we can understand.
    • asder
      i will next few days, thank you friend , do you work in 3D-BASIS-ME-MB software ?
Viewing 5 reply threads
  • The topic ‘TANK SEISMIC’ is closed to new replies.
