December 19, 2021 at 11:13 am
Sergiomedina_sm
SubscriberI am Sergio a student at the Polytechnic University of Castilla La Mancha (Ciudad Real). I am doing my end of studies work on the structural calculation of a water tank.
I am working with a SHELL63 tank for the tank walls; and a FLUID30 element, for the volume of water.
I am doing dynamic simulations: modal analysis and spectral analysis.
However, when I look at the displacement or warp of the modes, I only get the deformation of the fluid volume. I did not observe the deformation of the tank due to the fluid-structure interactions. How can I observe this? I am sending you my code so you can tell me how you can resolve this question; and if it has any bugs or improvements:
/PREP7
CSYS,1
*AFUN,DEG
/VUP,,Z
! ---------- CONSTANTS OR VARIABLES ----------
G = 9.81! Gravity acceleration
H1 = 1! LIQUID HEIGHT
H2 = 6! Total height of the tank
DIAM = 8! Fluid diameter
RAD = DIAM / 2! Fluid radius
PS = 7850! Steel mass density
IS = 206e9! Modulus of elasticity of steel in Pa (N / m2)
PW = 1000! Mass density of water
CW = 1483! SOUND SPEED WATER M / S
TAMEL = 0.3! TANK ELEMENT SIZE
ESP = 0.005! THICKNESS
MODES = 600! NUMBERS OF MODES
! -------- MATERIAL PROPERTIES --------
ET, 1, FLUID30! FLUID
MP, SONC, 1, CW
MP, DENS, 1, PW
R, 1
ET, 2, SHELL63! DEPOSIT
MP, EX, 2, ES
MP, PRXY, 2,0.3
MP, DENS, 2, PS
R, 2, ESP
! --------- FLUID DESIGN ------
CYL4,0,0, RAD, 45
AGE, 4,1 ,,,, 45
AGLUE, ALL
NUMMRG, KP
NUMCMO, ALL
ALLSEL
VEXT, ALL ,,,,, - H1
VGLUE, ALL
NUMMRG, KP
NUMCMO, ALL
ALLSEL
! ------- TANK WALL DESIGN -------
K, 13, RAD, 0, H2-H1
K, 14, RAD, 45, H2-H1
K, 15, RAD, 90, H2-H1
K, 16, RAD, 135, H2-H1
K, 17, RAD, 180, H2-H1
A, 1, 2, 14, 13
A, 2,4,15,14
A, 4,5,16,15
A, 5,6,17,16
ASEL, S ,,, 18,21,1
AGLUE, ALL
NUMMRG, KP
NUMCMO, ALL
ALLSEL
! ------ MESHING OF THE FLUID -----
TYPE 1
MAT, 1
R, 1
MSHAPE, 0.3D
MSHKEY, 1
AESIZE, EVERYONE, TAMEL
VMESH, ALL
NSEL, S ,,, ALL
CM, FLUID, NODE
ALLSEL
! ---------- MALLED DEPOSIT --------
TYPE 2
MAT, 2
REAL, 2
MSHAPE, 0.3D
MSHKEY, 1
ASEL, S ,,, 18,21,1
ASEL, A ,,, 10,16,3
ASEL, A ,,, 6
AMESH, ALL
ALLSEL
! ---------- CONDITIONS OF CONDITIONS ----------
NSEL, S, LOC, Z, -H1! SOIL NODES IMPEDED UX, UY, UZ
D, ALL, UX
D, EVERYONE, OU
D, EVERYONE, UZ
ALLSEL
NSEL, S, LOC, Z, 0! FREE CC WATER SHEET
SF, ALL, FREE
ALLSEL
CMSEL, S, FLUID! LIQUID WALLS CC FSI
NSEL, R, LOC, X, RAD
ESLN, S
ESEL, R, TYPE ,, 1
SF, ALL, FSI
ALLSEL
CSYS, 0
NSEL, S, LOC, Y, 0! PLANE NODES Y = 0 I PREVENT UY
D, ALL, UY
ALLSEL
ESEL, R, TYPE ,, 2! NODES MAT 2 IMPIDO ROTZ
NSLE
NSEL, R, LOC, Y, 0
D, ALL, ROTZ
CSYS, 1
ALLSEL
! --------- MODAL ANALYSIS ----------
/ SOLU
ANTYPE, MODAL
ACCEL, 0.0, G
MODOPT, UNSYM, MODES!, 50,1000
MXPAND, MODES ,,, YES
/ OUTPUT, DEP_LIQ3D, TXT
SOLVE
/ OUTPUT
SAVE
FINISH
! ---------- SPECTRAL ANALYSIS ----------
/ SOLU
ANTYPE, SPECTRUM
SPOPT, SPRS
SVTYP, 2.1
FREQ, 1e-2, .25,1,5,10,15,20,25,30
SV, 0,1,1,1,1,1,1,1,1,1
SED, 1.0,0.0,0.0
SRSS
/ OUTPUT, DEP_LIQ3D, TXT ,, APPEND
SOLVE
/ OUTPUT
SAVE
FINISH
/ POST1
RSYS, SOLU
/ INPUT, DEPOSCIL3D, MCOM
SAVE
December 20, 2021 at 4:02 pmmrife
Ansys EmployeeHi Sergiomedina_sm Please check the commands against the MAPDL Command Guide in the Help. AGE is not a APDL command and will do nothing...I suspect you mean to use AGEN? NUMCMO is not a APDL command...guess a simple typo and you mean to use NUMCMP. The Component 'EVERYONE' is not defined but used four times. And all the fluid elements have structural degrees-of-freedom. Usually we define two element types; fluid30 with and fluid30 without structural DOFs and set just those fluid elements connected to structural elements with the [fluid] type that has structural dof.
The entity numbering does not seem to be what you expect - perhaps due to the NUMCMP command not being used - so some of the other operations like meshing fail. Once you've edited the input file run it and see if there are any remaining warnings/errors about failed geometry operations and/or meshing.
Mike
December 20, 2021 at 8:58 pmSergiomedina_sm
SubscriberHello, if you excuse me I must have sent the code wrong. I send you the correct code.
Also, I have not understood what you mean in the second part of your answer: ¨And all the fluid elements have structural degrees-of-freedom. Usually we define two element types; fluid30 with and fluid30 without structural DOFs and set just those fluid elements connected to structural elements with the [fluid] type that has structural dof.¨
MODES = 600 ! NUMBERS OF MODES
ET, 1, FLUID30 ! FLUID
MP, SONC, 1, CW
MP, DENS, 1, PW
R, 1
ET, 2, SHELL63 ! DEPOSIT
MP, EX, 2, ES
MP, PRXY, 2,0.3
MP, DENS, 2, PS
R, 2, ESP
CYL4,0,0, RAD, 45
AGEN, 4,1 ,,,, 45
AGLUE, ALL
NUMMRG, KP
NUMCMP, ALL
ALLSEL
VGLUE, ALL
NUMMRG, KP
NUMCMP, ALL
ALLSEL
A, 1, 2, 14, 13
A, 2,4,15,14
A, 4,5,16,15
A, 5,6,17,16
ASEL, S ,,, 18,21,1
AGLUE, ALL
NUMMRG, KP
NUMCMP, ALL
ALLSEL
TYPE 1
MAT, 1
R, 1
MSHAPE, 0.3D
MSHKEY, 1
AESIZE,ALL,0.3
VMESH, ALL
NSEL, S ,,, ALL
CM, FLUID, NODE
ALLSEL
TYPE 2
MAT, 2
REAL, 2
MSHAPE, 0.3D
MSHKEY, 1
ASEL, S ,,, 18,21,1
ASEL, A ,,, 10,16,3
ASEL, A ,,, 6
AESIZE, ALL,0.3
AMESH, ALL
ALLSEL
NSEL, S, LOC, Z, -H1 ! SOIL NODES IMPEDED UX, UY, UZ
D, ALL, UX
D, ALL,UY
D,ALL, UZ
ALLSEL
NSEL, S, LOC, Z, 0 ! FREE CC WATER SHEET
SF, ALL, FREE
ALLSEL
CMSEL, S, FLUID ! LIQUID WALLS CC FSI
ESLN, S
ESEL, R, TYPE ,, 1
SF, ALL, FSI
ALLSEL
CSYS, 0
NSEL, S, LOC, Y, 0 ! PLANE NODES Y = 0 I PREVENT UY
D, ALL, UY
ALLSEL
ESEL, R, TYPE ,, 2 ! NODES MAT 2 IMPIDO ROTZ
NSLE
NSEL, R, LOC, Y, 0
D, ALL, ROTZ
CSYS, 1
ALLSEL
/ SOLU
ANTYPE, MODAL
ACEL, 0,0, 9.81
MODOPT, UNSYM, MODES !, 50,1000
SOLVE
/ OUTPUT
SAVE
FINISH
/ SOLU
ANTYPE, SPECTRUM
SPOPT, SPRS
SVTYP, 2.1
SED, 1.0,0.0,0.0
SRSS
SOLVE
/ OUTPUT
SAVE
FINISH
/ POST1
RSYS, SOLU
SAVE
January 4, 2022 at 11:30 amSergiomedina_sm
SubscriberI still can't figure this out. I need help!
January 5, 2022 at 1:49 pmAshish Khemka
I will close this post as you have one more similar post:
Tank axilsymmetric symmetry in ANSYS MECHANICAL APDL. ÔÇö Ansys Learning Forum
Regards Ashish Khemka
Viewing 4 reply threads- The topic ‘Tank axilsymmetric symmetry in ANSYS MECHANICAL APDL.’ is closed to new replies.
3301
1036
1006
859
804
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
