December 9, 2023 at 11:07 am
abankusomari
SubscriberGood day.please how do you assign a tangential magnetization to a permanent magnet in 2D and 3D using the magnet material properties in ansys electronics desktop .Thank you
December 11, 2023 at 4:01 pm
Timos
Ansys EmployeeTo assign a tangential magnetization to a permanent magnet in 2D and 3D using the magnet material properties in Ansys Electronics Desktop, you can follow the steps outlined in the document titled "How to model multi-directional magnetization of PMs in Maxwell?".
The document explains how to specify the magnetization direction according to different types of coordinate systems such as Cartesian, Cylindrical, or Spherical. The coordinate system type is specified in the material characteristics under "Material Coordinate System Type". The setup is based on vectors, which are defined by a magnitude and a direction. This information will be specified separately.
For example, if you are using a Cartesian coordinate system, you would specify the Cartesian coordinate system option, indicate the Magnitude (a value), and indicate the direction (X, Y, or Z). This information can be introduced using 1 or -1, depending on the direction.
For Cylindrical and Spherical coordinate systems, the procedure is the same but the direction will be R, Phi, and Z axes for Cylindrical and Rho, Theta, and Phi axes for Spherical.
The document also provides examples of how to set up multiple magnets, like in a PM motor, using the Cylindrical coordinate system.
References:
[1] Title: 'How to model multi-directional magnetization of PMs in Maxwell?', URL: '/knowledge/forums/topic/how-to-model-multi-directional-magnetization-of-pms-in-maxwell/' -
December 11, 2023 at 4:42 pm
abankusomari
SubscriberThank you Sir I am grateful.
- The topic ‘Tangential Magnetization in 2D’ is closed to new replies.
3597
1283
1117
1068
983
