August 8, 2021 at 10:26 pm
Ahmed_Aissa
SubscriberDear all,
When I set up my FSI simulation, I want/need my mesh to deform only once the coupling iterations reach convergence.
However, by using SystemCoupling GUI, although implicit mesh update was not ticked on, it is automatically activated, and within a few time-steps (if not the first time-step) my simulation fails.
I am looking for a way to desactivate implicit mesh update during my FSI simulation:
Disable implicit update from TUI command = did not work
The only solution I found useful is: Activate implicit mesh update and set the number of iteration to be very high.
I am running an FSI simulation where fluid to density ratio is equal to 1/ fluid is incompressible and Coupling is performed using the Quasi-Newton IQN-LS(q) method.
Thank you,
August 9, 2021 at 9:25 pmStephen Orlando
Ansys EmployeeHi Ahmed There is no built in way to do this.
Steve
August 16, 2021 at 5:29 pmAhmed_Aissa
SubscriberThank you for your answer Steve
Viewing 2 reply threads- The topic ‘SystemCoupling GUI + Implicit mesh update during FSI simulation’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4592
1494
1386
1209
