May 11, 2024 at 10:54 pm
denxyatx
SubscriberWhen i want to restart my system coupling two way fsi, the end time column changed to yellow color and cant modify it and cant restart or continue calculation. Is that a bug ?
May 11, 2024 at 10:56 pm
May 11, 2024 at 10:57 pm
May 14, 2024 at 8:14 am
Rahul
Ansys EmployeeHelloÂ
Time duration is controlled in System Coupling, but cannot be larger than the Step End Time set in Mechanical analysis settings.Refer following tutorial to know more about restarting coupled simulation: Restarting a Coupled Analysis in ANSYS Fluent and Mechanical (19.0) (youtube.com)
Hope this helps!
June 2, 2024 at 8:41 am
denxyatx
SubscriberHello, yes i set the end time step in system coupling and mechanical is same. But when i interrupted calculation, then start continue calculation again using restart point, the colomn of end time system coupling become yellow color, and i can do anything because when i input number of end time same or smaller than end time mechanical, it always yellow color. Please help me
June 2, 2024 at 8:49 am
denxyatx
SubscriberCan you try restart system coupling 2 way fsi in your ansys 2024 R1 sir? I use student version and compared to last settings to ansys student 2023R2. And its happening only in ansys 2024 R1
June 5, 2024 at 3:52 pm
July 2, 2024 at 2:05 pm
denxyatx
SubscriberHello,
I know whats the problem in system coupling ansys 2024R1 sir. Your computer should be used "." for decimal instead of "," and that is can set in control panel. For example decimal 0.001 instead of 0,001
- The topic ‘SYSTEM COUPLING, TWO WAY FSI, RESTART POINT’ is closed to new replies.
5664
1890
1419
1304
