October 30, 2025 at 9:57 am
TZakova
SubscriberHello,
I wanted to create a one way FSI in System Coupling from transient structure to fluid. Bellow is a screenshot of my set up. I suppressed the data transfer force.Â
When I do this, I can't input max/min interation steps in the solution control (see screenshot bellow).
When I unsupress the force data transfer inputting max/min iterations is possible. How can I run a one way fsi in system coupling and be able to input iterations?
I want to use system coupling and not workbench to not have to deal with workbench errors.
Thank you in advance!
October 30, 2025 at 12:58 pm
Federico
Ansys EmployeeHello,Â
since this is one-way coupling, you do not need Coupling Iterations to converge a Coupling Step. As long as your Transient Structural step is converged, the incremental displacements are passed onto Fluent and you can move on to the next Coupling Step.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4492
1494
1376
1209
