Ansys Free Student Software
system coupling of FSI cannot run
    • posada won
      I try to use fluent and transient structure to make FSI analysis. It can be setup in each system, but when I try to combine them to use the system coupling, it'll always give me the message as following. Hope to receive the solving method of problem.
      Transcript output started: 2023-02-16 11:12:24
      |                          Summary of Coupling Setup                          |
      |                          Coupling Participants (2)                          |
      | Participant: 流体流动(Fluent)                                                   |
      |    Type :                                                            FLUENT |
      |    UpdateControls:                                                          |
      |       Option :                                            ProgramControlled |
      |    Region: building                                                         |
      |       Topology :                                                    Surface |
      |       Input Variables :                                        displacement |
      |    Region: wall                                                             |
      |       Output Variables :                                              force |
      |    Variable: displacement                                                   |
      |       Quantity Type :                              Incremental Displacement |
      |       Location :                                                       Node |
      |       Tensor Type :                                                  Vector |
      |       Is Extensive :                                                  False |
      |       Data Type :                                                      Real |
      |    Variable: force                                                          |
      |       Quantity Type :                                                 Force |
      |       Location :                                                    Element |
      |       Is Extensive :                                                   True |
      |       Data Type :                                                      Real |
      | Participant: 瞬态结构                                                           |
      |    Type :                                                             MAPDL |
      |    UpdateControls:                                                          |
      |    Region: 流体固体界面                                                           |
      |       Input Variables :                                    力, Force_Density |
      |       Output Variables :                                               增量位移 |
      |    Variable: 力                                                              |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |    Variable: 增量位移                                                           |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |                              Analysis Control                               |
      | Analysis Type :                                                   Transient |
      | Global Stabilization :                                                 None |
      | OptimizeIfOneWay :                                                    False |
      | AllowSimultaneousUpdate :                                             False |
      | PartitioningAlgorithm :                              SharedAllocateMachines |
      |                           Coupling Interfaces (2)                           |
      | Interface: interface-1                                                      |
      |    Side: One        |
      |       Coupling Participant :                                   流体流动(Fluent) |
      |       Region List :                                                    wall |
      |       Reference Frame :                                GlobalReferenceFrame |
      |    Side: Two        |
      |       Coupling Participant :                                           瞬态结构 |
      |       Region List :                                                  流体固体界面 |
      |    Data Transfer: 数据传输                                                      |
      |       Suppress :                                                      False |
      |       Target Side :                                                     Two |
      |       Source Variable :                                               force |
      |       Target Variable :                                                   力 |
      |       Mapping Type :                                   Surface Conservative |
      |       Convergence Target :                                         1.00E-02 |
      |       Ramping Option :                                                 None |
      |       Relaxation Factor :                                          1.00E+00 |
      |    Mapping Control:                                                         |
      |       Absolute Gap Tolerance :                                      0.0 [m] |
      |       Face Alignment :                                    ProgramControlled |
      |       Poor Intersection Threshold :                                5.00e-01 |
      |       Relative Gap Tolerance :                                     1.00e+00 |
      |       Stop If Poor Intersection :                                      True |
      | Interface: interface-2                                                      |
      |    Side: One        |
      |    Side: Two        |
      |       Region List :                                                building |
      |    Data Transfer: 数据传输 2                                                    |
      |       Suppress :                                                      False |
      |       Target Side :                                                     Two |
      |       Source Variable :                                                增量位移 |
      |       Target Variable :                                        displacement |
      |       Unmapped Value Option :                                 Nearest Value |
      |       Mapping Type :                             Surface Profile Preserving |
      |    Mapping Control:                                                         |
      |                              Solution Control                               |
      | Duration Option :                                                   EndTime |
      | End Time :                                                          2.0 [s] |
      | Maximum Iterations :                                                      5 |
      | Minimum Iterations :                                                      1 |
      | Time Step Size :                                                    0.2 [s] |
      |                               Output Control                                |
      | Output Control Option :                                            LastStep |
      | Results        |
      |    IncludeInstances :                                     ProgramControlled |
      |    Type        |
      |       Option :                                                  EnsightGold |
      | Write Initial Snapshot :                                               True |
      | Warnings were found during data model validation.                           |
      | Warning: Participant 瞬态结构 (CouplingParticipant:Solution) has the            |
      |     ExecutionControl 'Option' set to 'ExternallyManaged'. System Coupling   |
      |     will not control the startup/shutdown behavior of this participant.     |
      | Warning: Participant 流体流动(Fluent) (CouplingParticipant:Solution 2) has the  |
      | 'cp950' codec can't encode character '\u6001' in position 1: illegal        |
      | multibyte sequence                                                          |
      Transcript output stopped: 2023-02-16 11:12:24
    • Federico
      Hello Posada,
      This error message is related to a Unicode encoding issue. This error is usually caused by attempting to use characters that are not supported by the chosen encoding. The 'cp950' codec is a traditional Chinese encoding that supports the Big5 character set, and it's possible that the character '\u6001' is not part of that character set.
  • The topic ‘system coupling of FSI cannot run’ is closed to new replies.
