March 29, 2022 at 5:52 pm
Aniket7017
SubscriberI am running a two way FSI coronary artery bifurcation simulation with artery being a hyperelastic material. I wanted to use quasi-newtonian stabalisation method so i extracted the system coupling and case file for both fluent and transient and did the necessary steps required to run the simulation through external system coupling gui(not inside workbench).i got results in EnSight format.Is there a way that i view result in CFD post and in mechanical post processor like i would have i,f i would have ran the system coupling in workbench itself.
Thank you
March 30, 2022 at 11:55 amKarthik Remella
AdministratorHello Can you save the results in a different format? .cdat or .cas (or.dat) would work in CFD Post.
Karthik
March 31, 2022 at 1:35 pmAniket7017
SubscriberHello The system coupling GUI doesnt provide me the option to save in different format.The results i got are two .case file and multiple .dat and .geo files.I tried opening one of the .dat file but got myself some error saying that the case files are missing
Thanks.
April 1, 2022 at 12:07 pmKarthik Remella
AdministratorHello Are they all in the same folder? You should be able to read the .dat files. Of course, you will need to have at least one corresponding .cas file in the same folder. Can you share a screenshot of the files you are attempting to read as well as the error message?
Karthik
April 1, 2022 at 12:08 pmKarthik Remella
AdministratorAnother method you can try is to Auto export .cdat files during your simulation run periodically when you set up your problem in Fluent. This could be a workaround. But for this, you will need to rerun your model. Just an FYI!
Karthik
April 1, 2022 at 3:15 pmStephen Orlando
Ansys EmployeePlease see the following tutorial for how to load System Coupling EnSight results into EnSight. EnSight is the preferred post-processor for FSI now. It can also load Fluent results (cas/dat, cas/cdat) and Mechanical results (.rst) https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_gen_postprocessing.html
Viewing 5 reply threads- The topic ‘System coupling GUI’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3892
1414
1241
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
