August 30, 2024 at 6:09 pm
rnegrete
SubscriberHi
I have a coupled analysis involving Fluent and Transient Mechanical. I´ve set up each application to use the GPU to accelerate the solution. If I run the solution with everything exactly the same except the transfer of forces and pressures done by System Coupling, the solutions run using the GPU, but if I use the System Coupling and transfer forces and pressures between Fluent and Mechanical, then the solution runs buy without using the GPU. How can I make a System Coupling Analysis using the GPU acceleration?
September 24, 2024 at 11:29 am
Rahul
Ansys EmployeeHello,
Fluent GPU solver with the System Coupling platform is not supported yet for two-way coupling. -
October 14, 2024 at 9:22 pm
rnegrete
SubscriberThank you. Any idea of when will it be supported or even if it's part of the roadmap?
6515
