3D Design
3D Design
SYS/Surface not wanted?
    • Adrian Ortega
      Hey! I'm new to Ansys;
      When creating a model I detached some parts so i could work with them individually while simulating, the thing is, spaceclaim created surfaces that have 0 thickness, thus not letting me try to solve the final model. If I delete these surfaces will it delete the objects from my model? Can I vary the thickness without altering the geometry of my model?
      The objective of doing this was to have a sole body to be concrete, while the others were structural steel, I can't assign the material to the bodies either.
      Thanks!
    • Akshay Maniyar
      Hi Adrian,
      Can you insert a screenshot of your original geometry from SC and explain what exactly you wanted to do? It will help to under your question in a better way and help you more effectively. I guess when you did detach in SpaceClaim it detached all the surfaces of the solid body.
      If you want to learn SC, you can check the below courses.
      Ansys SpaceClaim - Tools Tutorial - ANSYS Innovation Courses
      Advanced SpaceClaim Modeling - ANSYS Innovation Courses
      Solid Modeling With Ansys SpaceClaim | Ansys Courses
      Thank you,
      Akshay Maniyar
  • The topic ‘SYS/Surface not wanted?’ is closed to new replies.
