November 6, 2025 at 9:53 am
manish.pd
SubscriberHi,
Please share the syntax used in UDF for the granular temperature. I am simulating the blood flow through veins using Euler-Euler approach. For the RCB flow, I am using granular temperature model with PDE option. For writing UDFs to define static pressure and bulk viscosity, I need to call the granular temperature. I have tried many syntax suggestions provided by chatbots. None of these is working. Please share the actual syntax for granular temperature. The syntaxes I have already tried are:
- SV_GRANULAR_TEMPERATURE
- SV_GT
- SV_GRAN_TEMP
- SV_GRANULAR_TEMPERATURE_P
- SV_GRANULAR_TEMP_AP
Thank you
November 6, 2025 at 4:41 pm
khalidbinwaleed97
Subscriber#include "udf.h"
DEFINE_PROFILE(static_pressure_profile, thread, position)
face_t f;
real granular_temp;
begin_f_loop(f, thread)
granular_temp = C_GRANULAR_TEMPERATURE(f, thread);
/* Your calculations using granular_temp */
F_PROFILE(f, thread, position) = /* your expression */;
end_f_loop(f, thread)
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4492
1494
1376
1209
