March 19, 2019 at 1:39 pm
jonsys
SubscriberHello Community,
A sample of the bolt-pretension model that I am simulating with Workbench is depicted below:
1. Is there a possibility to apply symmetry if I use only half of the model (resulting from a cut of a plane in yz)?
2. I want to take half of the model cut by a plane in xy direction like in the picture below. Should the symmetry region be like depicted in order to get the same results as the full model?
Thank you
March 19, 2019 at 6:06 pm
peteroznewman
SubscriberI would expect either symmetry plane to work, but there is a difference in how you set the Pretension Force.
When you slice in the yz plane, you apply the full force, but when you slice in the xy plane, you apply only half the force.
March 20, 2019 at 4:24 pm
jonsys
SubscriberIt seems to give different results in each case
March 20, 2019 at 4:33 pm
peteroznewman
SubscriberPlease insert some screen shots to show the difference in results and show the bolt pretension in each case.
- The topic ‘symmetry in bolt pretension’ is closed to new replies.
3572
1188
1076
1063
952
