May 30, 2023 at 2:49 pm
Marius Carrier
SubscriberHello,
I have a geometry with round symmetrical features that includes multiple inlets. The goal was to utilize symmetry by grouping the left and right sides together and applying a symmetry boundary condition. However, I'm still experiencing flows in a manner that is not desired (picture below). What steps should I take to ensure that the flow exits from the right side and enters from the left side (and vice versa)?
Thank you for your help.
Regards.
May 30, 2023 at 3:04 pm
Federico
Ansys EmployeeHello Marius,Â
it is difficult to depict what your flow should look like from your picture. Can you share a screenshot of your domain?
May 30, 2023 at 3:31 pm
Marius Carrier
Subscriber -
May 30, 2023 at 3:46 pm
Federico
Ansys EmployeeBy domain, I mean your simulation domain or your model/geometry. It is still unclear to me what this should look like.
Are you sure it is symmetry that you are looking for? Or is this an outlet?Â
May 30, 2023 at 3:58 pm
Forum ModeratorDomain is the generic term for whatever you're modelling. So in this case, the CFD mesh/geometry.Â
Just a note, anything modelled using Student MUST be for your learning, and is therefore not confidential. Anything modelled with Research level licences is (technically) supposed to be published at some point. For commercial type or very confidential projects you should be using the Commercial level licences. Please discuss with your supervisor to make sure you're not accidentally outside the terms. If you're at all unsure please contact Ansys.Â
May 30, 2023 at 4:41 pm
Marius Carrier
SubscriberYes I'm sure I'm using the correct liscens. If you would tell me what you need I'm happy to provide you the info.
Do you undestand the problem I'm discribing?
May 30, 2023 at 4:02 pm
Marius Carrier
SubscriberI can't show you the whole domain. What exactly are you looking for?
Right now, it is treating the left wall of the geometry as a wall, despite implementing the symmetry condition on the walls. I want the airflow to perceive the left boundary not as a wall, but as a portal to the right wall. It is not an outlet because this would imply that the flow is exiting rather than entering from the right side.
May 30, 2023 at 5:26 pm
Federico
Ansys EmployeeI believe you are describing a periodic boundary.
May 31, 2023 at 9:00 am
Forum ModeratorTo add, symmetry is essentially a mirror surface so everything will "bounce off" it. As Federico suggests I think a periodic is what you're after: readÂ
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_bcs_sec_bound_cond.html
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_sec_periodic_hxfer.html
- The topic ‘Symmetry doesn’t work properly’ is closed to new replies.
5669
1890
1419
1304
