June 16, 2021 at 1:33 pm
AndreaPreziuso
SubscriberHi everyone!
I have problems in create a symmetry region in mechanical: i have to study a composite specimen that i have built in acp pre, when i move to mechanical's static strutural it doesn't show me the option of symmetry region but only pre-meshed cycling region. Is there something i can do to overcome this problem? Is it possible that with accademic licence is unavailable to put a symmetry region?
Another question: in mechanical's static structural the composite layers are visible only through the mesh (when i put the mesh the layers are well defined, otherwise they are not visible), can i view the layers outside the mesh visualization?
Thanks for the support!
June 23, 2021 at 8:59 am1shan
Ansys EmployeeFor solids you could use a zero displacement along the symmetry plane normal (and free other 2) to replicate a symmetry boundary condition. If its a surface body then you also need to fix rotations about the 2 axes which lie in the symmetry plane (and free rotation along axis along plane normal), in addition to adding zero displacement along plane normal.
Regards Ishan.
July 24, 2021 at 3:28 amBleri_vinci
SubscriberNice techniques. Thanks a lot.
Cheers Bl├®ri_Vinci
Viewing 2 reply threads- The topic ‘symmery region composites materials’ is closed to new replies.
