March 14, 2019 at 6:18 pm
mrdurango
SubscriberHi, I'm working on a hydrocyclone validation and I need to know what it is the turbulent viscosity equation for RNG k-e which depend on a swirl factor, k/epsilon and rotational tensor.
thanks.
March 15, 2019 at 9:43 am
Forum ModeratorThe equations are covered in the manual(s), and literature. However, I'd also suggest (very carefully) reading the model limitations and recommendations before choosing a different turbulence model!
March 19, 2019 at 10:18 pm
mrdurango
Hello rwoolhou , thank you for your answer.
As you suggested, I read in section "12.19.6 Swirl Modification" (from 12.19.6 Swirl Modification) the default swirl constant (
in Equation 12.4-8 ) is set to 0.07 (what is this "swirl constant" in the first place?). However, equation 12.4-8 from RNG Swirl Modification:
only shows the functional dependence on
, but not the function itself. From the theoretical point of view, I want to know how this function is included in the model since I have not found any literature (apart from here) where such a relationship is used. We know (eq. 12.4-7):
My question then is: why this swirl factor is included? what is "f" in eq. 12.4-8, i.e what is the function that corrects the turbulent viscosity in eq. 12.4-7 by using
and
I would be very grateful if you could point me to any articles about this, since to my knowledge, the k-e model doesn´t incorporate any "swirl factor" in its equations.
Thank you for your time.
Marvin.
March 20, 2019 at 9:19 am
Forum ModeratorI was referring to the limitation of the 2-equations models: we never use them for cyclones. You need to use the RSM Model and a good quality hex or poly mesh.
Most of the equations should also have references (use the R19 support: v6 is about 17-18 years old), I can't comment other than to refer you to those: not that they're needed as you'll be reading the limitations!
March 20, 2019 at 9:20 pm
mrdurango
SubscriberHello rwoolhou, thank you for your answer. I looked into the last version of fluent documentation and it says the same I showed you. I know it is not recommended to work with RNG k-e in cyclones, and I have as well used the RSM Model and obtained good results. Apart from this, however, my question persists, what is the "swirl factor" and how it is implemented into the k-e model equations, it seems to me a bit obscure.
Thank you for your time again!
Marvin
March 21, 2019 at 7:13 am
Amine Ben Hadj Ali
Ansys EmployeeThe function is not published and is confidential.
- The topic ‘Swirl Factor RNG k-epsilon (Swirl dominated flow)’ is closed to new replies.
- affinity not set
3862
1414
1231
1118
1015
